Use the following procedure to set the trust factor associated with a port for DHCP Snooping. By default, the trust factor is set to untrusted on all ports.
![Note](images/note.png)
For ports that are members of an MLT, DHCP Snooping must be configured using the MLT configuration mode.
To enable DHCP Snooping on a port, you must enable DHCP Snooping globally.
- Select DHCP Snooping.
- Select the DHCP Snooping-port tab.
- In the row for the port, double-click DhcpSnoopingIfTrusted, and select trusted or untrusted.
- Select Apply.
DHCP Snooping-port Field Descriptions
Use data in the following table to use the DHCP Snooping-port tab.
Name |
Description |
Port |
Specifies the port on the switch. |
DhcpSnoopingIfTrusted |
Specifies if the switch ports are trusted for DHCP Snooping. By default, it is set as untrusted. |
